Edge 800: neue Firmware 2.20
  • Für den Edge 800 gibt es eine neue Firmware:
    http://www.garmin.com/support/downlo...ls.jsp?id=5238
    Changes made from version 2.10 to 2.20:
    • Added setting to turn on 1 second recording in Settings > System > Data Recording.
    • Fixed an issue that could cause large jumps in position and distance.
    • Added Last Lap Power data field.
    • Fixed an issue that was causing ANT sensors to not pair as expected.
    • Added a setting to enable a prompt to recalculate during navigation.
    • Courses are now usable with GPS turned Off and a connected ANT+ Speed sensor.
    • The Virtual Partner can now be manually synchronized by pressing and holding on the Virtual Partner graphic.
    • Fixed a speed zone field display issue.
    • Improved course navigation.
    • Fixed issues viewing an activity in progress from the history menu.
    • Fixed issue with some Mac users not being able to connect to device without resetting the timer.
    • Fixed some display issues when using a weight scale.
    • Fixed an issue that could cause distance to not accumulating after switching bike profiles while the timer is running.
    • Fixed a few issues while editing workouts and a display issue while doing a workout in night mode.
    • Fixed a display issue while doing a workout in night mode.
    • Improved elevation calibration when manually setting device elevation.
