@Gpsfun, dazu braucht man dann ein PDA?
Der Export nach PDA erfolgt aus der Kompass Software heraus?
Ok i will write english ( but still not my Muttersprache)
I think it is necessary to connect PDA to PC. ( not necessary to install Digital Kompass Software on it). I laso tried this ''system'' with Android Phone but doesn't work. Maybe with windows mobile phone i don't know. But connecting PDA with WIN CE will work for sure.
What i did fighting with this problem
1. Open DKL3D.exe file
2. Mark area you want export to PDA ( i exported 2 parts separatelly)
3. Click Export to Pda - Pc now will work -as i saw later creating few files in Kompass Digital Maps/PPC folder
4.After some time PC ask whare on PDA save exported files .
I dont remember exactly but then we saw message like ,, on PDA Kompass Digital Software is not installed- anyway export?) Click yes and after some time you will have few files ( 4 i think) like .gmp, .gvg on your PDA.
If you click Cancel program stops but you will find files ready to export in Kompass Digital Maps/PPC folder on your PC. ( maybe this is better solution)
5.Open 2 maps in Compe Gps Land -registered. (Trial can not do it ).
6.Select maps and what very important . You have to set ,,SCALE '' to some value ( i did with 75% or with 100% ).But don't let 1% then you will have empfty map after merging.
7.Merge maps
8.Save destination
I think these Procedure is necessary with big maps ( 1gb or more) My created maps works well in Locus.
When some problems later I will make screens.
