Probleme mit MOBAC und lokalen Tiles
    ich komme mit MOBAC nicht weiter und finde keine Erklärung für den Fehler.
    Ich habe mit Maperitive einen kleinen Kartenausschnitt in den Zommleveln 8-13 erstellt und das Verzeichnis in MOBAC eingebunden.
    Beim Aufruf bringt MOBAC eine Fehlermeldung:
    2015-08-19 13:20:12,910 DEBUG [Map preview thread 4] CustomLocalTileFilesMapSource: Map tile file not found: F:\Navigation\Maperitive\Tiles\8\167\131.png
    2015-08-19 13:20:12,911 DEBUG [Map preview thread 4] CustomLocalTileFilesMapSource: Map tile file not found: F:\Navigation\Maperitive\Tiles\8\167\131.png
    2015-08-19 13:20:12,912 DEBUG [Map preview thread 5] CustomLocalTileFilesMapSource: Map tile file not found: F:\Navigation\Maperitive\Tiles\8\166\131.png
    2015-08-19 13:20:12,913 DEBUG [Map preview thread 1] CustomLocalTileFilesMapSource: Map tile file not found: F:\Navigation\Maperitive\Tiles\8\166\130.png
    2015-08-19 13:20:12,914 DEBUG [Map preview thread 1] CustomLocalTileFilesMapSource: Map tile file not found: F:\Navigation\Maperitive\Tiles\8\166\130.png
    2015-08-19 13:20:12,915 DEBUG [Map preview thread 2] CustomLocalTileFilesMapSource: Map tile file not found: F:\Navigation\Maperitive\Tiles\8\167\130.png
    2015-08-19 13:20:12,916 DEBUG [Map preview thread 3] CustomLocalTileFilesMapSource: Map tile file not found: F:\Navigation\Maperitive\Tiles\8\168\130.png
    2015-08-19 13:20:12,917 DEBUG [Map preview thread 4] CustomLocalTileFilesMapSource: Map tile file not found: F:\Navigation\Maperitive\Tiles\8\168\131.png
    2015-08-19 13:20:12,918 DEBUG [Map preview thread 4] CustomLocalTileFilesMapSource: Map tile file not found: F:\Navigation\Maperitive\Tiles\8\168\131.png
    2015-08-19 13:20:12,919 DEBUG [Map preview thread 5] CustomLocalTileFilesMapSource: Map tile file not found: F:\Navigation\Maperitive\Tiles\8\168\132.png
    2015-08-19 13:20:12,920 DEBUG [Map preview thread 1] CustomLocalTileFilesMapSource: Map tile file not found: F:\Navigation\Maperitive\Tiles\8\167\132.png
    2015-08-19 13:20:12,921 DEBUG [Map preview thread 2] CustomLocalTileFilesMapSource: Map tile file not found: F:\Navigation\Maperitive\Tiles\8\166\132.png
    2015-08-19 13:20:12,922 DEBUG [Map preview thread 3] CustomLocalTileFilesMapSource: Map tile file not found: F:\Navigation\Maperitive\Tiles\8\165\132.png
    2015-08-19 13:20:12,923 DEBUG [Map preview thread 4] CustomLocalTileFilesMapSource: Map tile file not found: F:\Navigation\Maperitive\Tiles\8\165\131.png
    2015-08-19 13:20:12,924 DEBUG [Map preview thread 5] CustomLocalTileFilesMapSource: Map tile file not found: F:\Navigation\Maperitive\Tiles\8\165\130.png
    2015-08-19 13:20:12,925 DEBUG [Map preview thread 1] CustomLocalTileFilesMapSource: Map tile file not found: F:\Navigation\Maperitive\Tiles\8\165\129.png
    2015-08-19 13:20:12,926 DEBUG [Map preview thread 2] CustomLocalTileFilesMapSource: Map tile file not found: F:\Navigation\Maperitive\Tiles\8\166\129.png
    2015-08-19 13:20:12,927 DEBUG [Map preview thread 3] CustomLocalTileFilesMapSource: Map tile file not found: F:\Navigation\Maperitive\Tiles\8\167\129.png
    2015-08-19 13:20:12,928 DEBUG [Map preview thread 4] CustomLocalTileFilesMapSource: Map tile file not found: F:\Navigation\Maperitive\Tiles\8\168\129.png
    2015-08-19 13:20:12,932 DEBUG [Map preview thread 5] CustomLocalTileFilesMapSource: Map tile file not found: F:\Navigation\Maperitive\Tiles\8\169\129.png
    2015-08-19 13:20:12,933 DEBUG [Map preview thread 5] CustomLocalTileFilesMapSource: Map tile file not found: F:\Navigation\Maperitive\Tiles\8\169\129.png
    2015-08-19 13:20:12,933 DEBUG [Map preview thread 5] CustomLocalTileFilesMapSource: Map tile file not found: F:\Navigation\Maperitive\Tiles\8\169\130.png
    2015-08-19 13:20:12,934 DEBUG [Map preview thread 5] CustomLocalTileFilesMapSource: Map tile file not found: F:\Navigation\Maperitive\Tiles\8\169\130.png
    2015-08-19 13:20:12,934 DEBUG [Map preview thread 5] CustomLocalTileFilesMapSource: Map tile file not found: F:\Navigation\Maperitive\Tiles\8\169\131.png
    2015-08-19 13:20:12,935 DEBUG [Map preview thread 5] CustomLocalTileFilesMapSource: Map tile file not found: F:\Navigation\Maperitive\Tiles\8\169\132.png
    2015-08-19 13:20:12,942 DEBUG [Map preview thread 1] CustomLocalTileFilesMapSource: Map tile file not found: F:\Navigation\Maperitive\Tiles\8\164\132.png
    2015-08-19 13:20:12,944 DEBUG [Map preview thread 5] CustomLocalTileFilesMapSource: Map tile file not found: F:\Navigation\Maperitive\Tiles\8\164\131.png
    2015-08-19 13:20:12,944 DEBUG [Map preview thread 1] CustomLocalTileFilesMapSource: Map tile file not found: F:\Navigation\Maperitive\Tiles\8\164\130.png
    2015-08-19 13:20:12,945 DEBUG [Map preview thread 1] CustomLocalTileFilesMapSource: Map tile file not found: F:\Navigation\Maperitive\Tiles\8\164\130.png
    2015-08-19 13:20:12,945 DEBUG [Map preview thread 2] CustomLocalTileFilesMapSource: Map tile file not found: F:\Navigation\Maperitive\Tiles\8\164\129.png
    Diese ist jedoch völlig unerklärlich, im Level 8 gibt es nur ein png:
    Der gerenderte Bereich liegt um Gera, definitiv im Bild enthalten.
    Weiß jemand wie es zu dieser Meldung kommt, sämtliche erforderlichen png sind vorhanden, dies ist mein x-ter Versuch - immer das gleiche Ergebnis?
    Weiß mir nicht mehr zu helfen :confused:
    Woher bezieht MOBAC das Wissen über die konkreten Namen und wieso ergibt die Ausgabe von M. eine völlig andere als MOBAC erwartet?
    Die tiles enthält keine Angaben dazu?
    Verzeichnisstruktur habe ich mal angehängt.
    cu
  • Vermutlich ist der Dateipfad in der XML, die du für Mobac gebastelt hast, nicht in Ordnung.
    Fehler gefunden.
    Das Anzeigefenster von MOBAC muss innerhalb der Koordinaten stehen, in denen die Tiles von Maperitive liegen.
    cu
