Hallo zusammen,
ich steh grad vor dem Problem, einen Satz Portugal-Rasterkarten in QMapShack einbinden zu wollen.
Diese liegen in .gif mit .map vor.
Code
			for file in *.map
gdal_translate -co COPY_SRC_OVERVIEWS=YES -co TILED=YES -co COMPRESS=LZW "$file" "${file%.*}".tifsollte diese in Geo-TIFFs wandeln, aber ich bekomme Fehlermeldungen:
Code
			ERROR 1: Failed to find datum Datum Lisboa (Portugal) in ozi_datum.csv.
Input file size is 5339, 3340
0...10...20...30...40...50...60...70...80...90...100 - done.es entsteht zwar ein .tif, aber das ist nicht georeferenziert. Das sagt QMapShack:
Code
			[COLOR=#0000ff]0...10...20...30..[/COLOR][COLOR=#ff0000]Warning 6: gdalbuildvrt does not support ungeoreferenced image. Skipping ~/TopKarten/Portugal-25k/001.tif[/COLOR]Hier ein beispielhaftes .map
Code
			OziExplorer Map Data File Version 2.2
M888 - 001
1 ,Map Code,
Datum Lisboa (Portugal),WGS 84,   0.0000,   0.0000,WGS 84
Reserved 1
Reserved 2
Magnetic Variation,,,W
Map Projection,Transverse Mercator,PolyCal,No,AutoCalOnly,No,BSBUseWPX,No
Point01,xy,  337,  336,in, deg,    ,        ,N,    ,        ,W, grid,   ,     185000,     579000,N
Point02,xy, 5002, 3001,in, deg,    ,        ,N,    ,        ,W, grid,   ,     199000,     571000,N
Point03,xy, 5002,  337,in, deg,    ,        ,N,    ,        ,W, grid,   ,     199000,     579000,N
Point04,xy,  336, 3003,in, deg,    ,        ,N,    ,        ,W, grid,   ,     185000,     571000,N
Point05,xy, 2003, 1004,in, deg,    ,        ,N,    ,        ,W, grid,   ,     190000,     577000,N
Point06,xy, 3669, 2338,in, deg,    ,        ,N,    ,        ,W, grid,   ,     195000,     573000,N
Point07,xy, 3669, 1003,in, deg,    ,        ,N,    ,        ,W, grid,   ,     195000,     577000,N
Point08,xy, 2002, 2337,in, deg,    ,        ,N,    ,        ,W, grid,   ,     190000,     573000,N
Point09,xy, 3004, 1669,in, deg,    ,        ,N,    ,        ,W, grid,   ,     193000,     575000,N
Point10,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point11,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point12,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point13,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point14,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point15,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point16,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point17,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point18,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point19,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point20,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point21,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point22,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point23,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point24,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point25,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point26,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point27,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point28,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point29,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Point30,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,           ,           ,N
Projection Setup,    39.666666667,    -8.131906667,     1.000000000,       200000.00,       300000.00,,,,,
Map Feature = MF ; Map Comment = MC     These follow if they exist
Track File = TF      These follow if they exist
Moving Map Parameters = MM?    These follow if they exist
MM0,Yes
MMPNUM,4
MMPXY,1,0,0
MMPXY,2,5336,0
MMPXY,3,5336,3336
MMPXY,4,0,3336
MMPLL,1,  -8.325720,  42.187861
MMPLL,2,  -8.131900,  42.188012
MMPLL,3,  -8.131873,  42.097892
MMPLL,4,  -8.325418,  42.097741
MM1B,2.999459
LL Grid Setup
LLGRID,No,No Grid,Yes,255,16711680,0,Geen label,0,16777215,7,1,Yes,x
Other Grid Setup
GRGRID,Yes,1 Km,No,8388608,12632256,1 Km,8388608,16777215,8,1,Yes,No,Yes,x
MOP,Map Open Position,0,0
IWH,Map Image Width/Height,5339,3340gdal Info liefert:
Code
			gdalinfo 001.map
Driver: MAP/OziExplorer .MAP
Files: 001.map
Size is 5339, 3340
Coordinate System is `'
GCP Projection =
GCP[  0]: Id=, Info=
          (337,336) -> (185000,579000,0)
GCP[  1]: Id=, Info=
          (5002,3001) -> (199000,571000,0)
GCP[  2]: Id=, Info=
          (5002,337) -> (199000,579000,0)
GCP[  3]: Id=, Info=
          (336,3003) -> (185000,571000,0)
GCP[  4]: Id=, Info=
          (2003,1004) -> (190000,577000,0)
GCP[  5]: Id=, Info=
          (3669,2338) -> (195000,573000,0)
GCP[  6]: Id=, Info=
          (3669,1003) -> (195000,577000,0)
GCP[  7]: Id=, Info=
          (2002,2337) -> (190000,573000,0)
GCP[  8]: Id=, Info=
          (3004,1669) -> (193000,575000,0)
Metadata:
  NEATLINE=POLYGON ((-8.32572 42.187861,-8.1319 42.188012,-8.131873 42.097892,-8.325418 42.097741,-8.32572 42.187861))
Corner Coordinates:
Upper Left  (    0.0,    0.0)
Lower Left  (    0.0, 3340.0)
Upper Right ( 5339.0,    0.0)
Lower Right ( 5339.0, 3340.0)
Center      ( 2669.5, 1670.0)
Band 1 Block=5339x1 Type=Byte, ColorInterp=Palette
  Metadata:
    GIF_BACKGROUND=0
  Color Table (RGB with 16 entries)
    0: 16,0,0,255
    1: 156,49,49,255
    2: 156,49,0,255
    3: 156,49,98,255
    4: 246,205,255,255
    5: 205,49,16,255
    6: 156,205,164,255
    7: 246,255,246,255
    8: 156,0,0,255
    9: 57,49,41,255
   10: 0,49,41,255
   11: 205,205,98,255
   12: 172,156,106,255
   13: 74,98,98,255
   14: 205,98,49,255
   15: 156,98,57,255Nun hab ich noch eine datums.dat
Code
			Datum Lisboa (Portugal), 29, -304.046, -60.576, 103.640
European 1950 (Portugal), 14, -87.987, -108.639, -121.593Was kann ich jetzt mit dem allem anfangen? Ich bräuchte irgendwie einen Schups in die richtige Richtung  :).
