EDGE 1030 - Neue Firmware
  • Edge 1030 software version 3.50
    Changes made from version 3.20 to 3.50:
    Fixed issue causing the map to crash (Changes made from version 3.40 to 3.50)
    Added Shimano Di2 2.0 support.
    Added Vector 3 software update support.
    Improved Grade accuracy on steep climbs.
    Fixed issue preventing activities from being saved on an SD card.
    Fixed several Varia Vision issues.
    Fixed issues with performance condition display and data recording.
    Fixed issue preventing training status and training load from being uploaded to Garmin Connect.
    Fixed an issue allowing Connect IQ Apps to disable sensors.
    Fixed issue causing the back key to not display in CIQ apps.
    Fixed issue causing crashes when using 3D map mode.
    Fixed issue that could cause a crash while using Strava Segment Explore map preview.
    Updated recovery time calculation requirements. To trigger a recovery time, ride with a heart rate sensor for ten minutes at moderate to high intensity
    http://www8.garmin.com/support/download_details.jsp?id=12335
    Download Firmware 3.20 and 3.50: http://members.kabsi.at/Wirth/Bilder/Edge1030_320&350.zip
  • Edge 1030 software version 3.60
    Changes made from version 3.50 to 3.60:
    •Added sharp bend notifications while not navigating. These notifications can be disabled by selecting Menu > Activity Profiles > [select a profile] > Navigation > Sharp Bend Warnings.
    •Added Connect IQ 2.4.1 support.
    •Added Wi-Fi support for Strava Segment Explore.
    •Added VIRB camera widget and VIRB 360 settings support.
    •Fixed issue where the turn list sent to the Varia Vision could get out of sync and cause the Edge to crash.
    •Fixed Training Effect inaccuracies, Training Load peaks that were over-inflated, and the Stress Score feature.
    •Fixed issue where segments would not display on the map and allowed the Segments activity profile option to control whether segments display or not.
    •Fixed issue where the Edge would not receive sensor software updates.
    •Fixed issue causing erroneous GPS position on iPhone.
    •Improved graphics performance.
    •Made stability improvements.
    Download Firmware http://www.hochladen.to/files/ESCtg6Ch1512053889.html
  • Monika
    Hat das Label Edge 1000 Serie hinzugefügt.
