GPSMap 66sr Firmware 3.30 Firmware ist da
  • GPSMap 66sr Firmware 3.30 Firmware ist da!
    Changelog:
    • Fixed possible shutdown when sending a Quick Text from inReach Remote.
    • Fixed issue with weather map not defaulting to active weather position.
    • Fixed possible issues with items missing during Explore Sync.
    • Fixed an issue where certain submenus could be draws off screen.
    • Fixed issue setting custom waypoint offsets using filename.
    • Fixed possible issues that caused the main menu to draw over the current page.
    • Fixed possible shutdown related to BirdsEye direct downloads.
    • Fixed possible issue getting stuck on a page after powerup.
    • Fixed possible issues with postal code searches.
    • Fixed issue where proximity alerts would only alert once.
    • Fixed missing alerts from points loaded using POI loader tool.
    • Fixed adding hidden SSID networks.
    • Fixed possible issues with time restricted speed limits.
    • Fixed navigation to a geocache to always continue until ended by user.
    • Fixed geocache file list to wrap.
    • Fixed some issues with geocache photos.
    • Fixed issue where certain pages could incorrectly appear to have tabs.
    • Fixed issue where fit activities could be missing start time data.
    • Fixed issue where bearing line would not appear on map in CDI compass mode.
    • Improved recent finds list to include navigation started from the map.
    • Improved functionality of navigation features with Explore.
    • Improved round trip routing setup experience.
